Cross-sketch constraints "failed to regenerate"
martin_meinke
Member Posts: 5 ✭
Hi everyone!
I am pretty new to onshape and really like it so far!
Still, right now I am struggling with what feels like a trivial problem - introducing a constraint "between sketches".
I have tried to make this work for an hour, but just can not figure out what might be the problem.
I'd highly appreciate if someone could have a quick look:
https://cad.onshape.com/documents/c4d93042f556b439a8561fbf/w/a1dadf21232ad4bb82d6a260/e/a2ea35d7bbaa35b166155245
NeilCooke
Moderator, Onshape Employees Posts: 5,926
Because the feature list is regenerated top to bottom like a recipe and Sketch 2 did not exist when Sketch 1 was created. Or in other words, you can't alter the past.Senior Director, Technical Services, EMEA0
Let me try to be more precise:
Why does onshape not increase the width of the rectangle in Sketch1 to accommodate the width constraint in Sketch2? This should be possible without violating any constraints?
https://cad.onshape.com/help/Content/sketch-tools-use.htm?Highlight=Use
