Send control input to Onshape using the API
Overlord6464
Member Posts: 5 EDU
Hello,
I'm currently trying to integrate the control input from a DIY 3D Mouse into onshape.
I would like to know if it exist a custom api call to send control input in the current part studio or assembly.
For example something like :
-My mouse detect a rotation.
-Software transform this rotation to an api call and send the input to the current view.
Someone knows which part of the api I should look into ?
Thanks
Thanks
MichaelPascoe
Member Posts: 2,814 PRO
From what I know, this is not currently possible. 3DConnexion has a special deal with Onshape which is how they can do it. Onshape listens on a port to messages from space mouse and acts accordingly. There is probably a way to piggy back off of the space mouse drivers if you know what your doing.
RENDERCAD
________________________________________________________________________0
RENDERCAD
If you can capture the mouse data, you can send that to the API with a pretty simple script.
Do you have any sample script or API reference that I can take a look into ?
On your video it's seems your directly modifying the assembly not rotating the view ?
Thanks for the insight
Is your breakout board hooked to your computer or does it have a wifi chip on it?
Is rotating a view a API thing?
Nope, you can turn on the network console and see the calls the client makes to the server. Spinning a model does not create a get or post call to the server. Since the API deals with the server, you're not going to rotate the screen with a 3DConnexion by making calls to the server.
Onshape is a cloud app which brings along with it some surprising facts. Onshape has no access to the files on your computer and it can not see any of the hardware. Chrome has access to a computer's hardware. It's a security thing.
What is it then?
Inspect elements tab shows that the viewport is a canvas tag which is used by webgl.
Does webgl allow 3D input devices?
Yes, you can build a simple website that'll spin something with a 3DConnexion.
Can you tap into the Onshape tab from a tab you created?
No, you can not build a website that'll read about the other tabs in a browser. It's security thing.
Onshape doesn't allow you to peggy back onto their client tab in a browser. There is no client api. You can't customize the client. Even though they have a connection to a 3DConnexion device through the canvas tag, you don't have access to it.
3DConnexion has an API and you might pretend that your device is a 3DConnexion.
I think the solution to your problem is a hardware to computer issue. Keep in mind that the cloud has no access to the hardware attached to your computer. It's a security thing.
If you get it working please post how you did it.
Are you serving on localhost? Are you on a PC or Mac?
