Chain Select for picking curves? (eg Selecting "closed loop" for a surface)
Since I can't select a sketch area to create a surface, must pick sketch entities... (I haven't tried "click and drag" a window yet)...I want to "Chain-Select" the curves. OK... dragging a window did work. I had only the sketch I wanted displayed...
andy_morris Moderator, Onshape Employees Posts: 87
When the Extrude dialog is open and the option set to "surface" you can select the sketch from the Feature List. This will create a surface(s) from all the entities in the sketch.Andy Morris / Head of Product Design / Onshape, Inc.5
Currently, Onshape is fairly weak in this area, it seems to me.
What's more, some of the present tools promise more than they deliver, which is contrary to the usual Onshape pattern:
The current RMB "Create Selection" tool (the one which permits selection of faces, around a protrusion or hole, or "tangent connected") creates a false impression, it seems to me, by pretending to be active and available in sketch mode, and it wastes the user's time establishing whether it works.
For instance, "tangent connected" makes it seem as though it might work for selecting a chain of lines and arcs in a sketch. It doesn't.
