remove a body in featurescript
rooiejoris
OS Professional Posts: 16 PRO
As I start always: I am not a programmer, but I think I want something fairly simple:
I want to remove all bodies with a volume smaller than X
the println works so the condition works as well, I just can't get it done that it actually deletes the bodies.
documentation says something with opDeleteBodies, but I can't figure the right arguments/values/whatever
you can see the script in the second tab of https://cad.onshape.com/documents/bced954384551d9a45056666/w/1c4ec0f34b9d2439e54967bb/e/efbe92356f7e4fdb9a7ffea8?renderMode=0&uiState=65cc8eb5ce42ed723b91737c
thanks in advance...!!
cheers / joris
FeatureScript 2260;//import(path : "onshape/std/common.fs", version : "2260.0");
import(path : "onshape/std/geometry.fs", version : "993.0");
annotation { "Feature Type Name" : "remove_larger_volume" }
export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
precondition
// Define the parameters of the feature type
//println("dit is het begin");
println("start");
setVariable(context, "test", 1); // test
// Define the function's action
for (var part in evaluateQuery(context, qAllModifiableSolidBodies()))
//var partName = getProperty(context, { "entity" : part, "propertyType" : PropertyType.NAME } );
var volume = evVolume(context, { "entities" : part });
//volume = volume;
println(volume);
if (volume <= 0.0002 *meter*meter*meter) {
println("tada");
opDeleteBodies(context, id + "deleteBodies1", {
"entities" : entity
println("end");
});you can see the script in the second tab of https://cad.onshape.com/documents/bced954384551d9a45056666/w/1c4ec0f34b9d2439e54967bb/e/efbe92356f7e4fdb9a7ffea8?renderMode=0&uiState=65cc8eb5ce42ed723b91737c
cheers / joris
Konst_Sh
Member Posts: 110 PRO
when in the loop every context operation with id should have unique id, so you need to use iterator variable to build the id:for (var i, part in evaluateQuery(context, qAllModifiableSolidBodies())) {
opDeleteBodies(context, id + ("deleteBodies" ~ i), { "entities" : entity });
}At some moment you will want to perform multiple operation in the loop, in this case it might be more handy to construct the id of the whole iteration first:
const id = id + "iteration" + i; // the id from the outer scope is shadowed here for the scope of the for loop
opDeleteBodies(context, id + "deleteBodies", { "entities" : entity });
//another op_ functions with id here
}Also in your case I would do it in slightly another way:const toDelete = evaluateQuery(context, qAllModifiableSolidBodies())->filter(function(body){
const volume = evVolume(context, { "entities" : body});
return volume <= 0.0002 *meter*meter*meter;
->qUnion();
if(!isQueryEmpty(context, toDelete)) {
"entities" : toDelete
else{
println("No bodies below the volume limit");
for (var i, part in evaluateQuery(context, qAllModifiableSolidBodies())) {const id = id + "iteration" + i; // the id from the outer scope is shadowed here for the scope of the for loop
->qUnion();
else{
thanks for the explanation, I will try to understand it more, but if you don't program that much it is a bit dazzling.
I didn't try the suggestions for the for loop, but tried you suggestion.
Didn't work first, but that was because I didn't import the right things in the beginning:
this works:
this doesn't
and this also not
thanks again!!
cheers / joris
