Drawing rebuilds too sensitive. Anyone else have this problem with release management?
brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
edited September 2018 in Drawings
I am trying to use release management and have a list 22 drawings I am trying to release in 1 go.  After selecting I find 2 are pending, this is after a lot of attempts to ensure all are updated.
so I update the 2 pending drawings.
Then have another go.
 It seems that just updating 1 drawing cause's another to go into pending update. This doesn't seem right!!!
It seems my best solution, for now, is just to turn the pending off.
    Now I am having trouble getting my part studio's to show without regen errors, I've checked this 5 times now. Looks like I'll have to turn that one off too.
  • mthiesmeyermthiesmeyer Onshape Employees Posts: 115 image
    Hi @brucebartlett,
    This also does not seem correct, please file a support ticket.
    Best,
    Mike
  • romeograhamromeograham Member, csevp Posts: 740 PRO
    I have a similar issue.
    The workflow to use Release Management with several parts at once is really challenging. Since you can't "save" your list of parts / drawings etc that you want to release, you have to Cancel out of the the Release page, then go find / fix all the problem areas, then come back and manually create that long list again!
    I'd like to be able to select multiple Drawings from the Tab Manager and release from there.
