Solved recurrent error on loft: "current selection would create a self intersecting body" SOLVED
Lyle_WalshLyle_Walsh Member Posts: 46
edited November 2018 in General
I keep getting this error and last time I solved it by generating the end shapes over and over and it finally worked, any ideas what I am doing wrong?  The shape has no errors, it is completely selectable so no holes.  wracking my brain here.
https://cad.onshape.com/documents/856ebdce6c4cedced2e02bde/w/2ff1b4330205e9e8369a0db2/e/75afb35640c3e13ea487578c
    You can see from the image that the purple path preview is showing self intersection at the bottom of the hook. You will have to make your profile smaller or your guide curve less tight.
  • Lyle_WalshLyle_Walsh Member Posts: 46
    yup thanks
    sigh can't figure out how to mark answered, the did this answer your question question isnt there
    @Lyle_Walsh
    I think you posted this as a Discussion, not a Question.  Only Questions have answers.
