Using point pattern in asemblies
Hi,
I need to use @cody_armstrong 's point pattern in an assembly to replicate parts.
Did anyone figure out how to?
  • MBartlett21
    @Benjamin_Dellal
    You can't use it in an assembly. You can vote up this improvement request for custom features in assemblies:
    https://forum.onshape.com/discussion/9663/featurescript-for-assembly#latest
    IR for AS/NZS 1100
  • cody_armstrong
    cody_armstrong Moderator, Onshape Employees, Developers, csevp Posts: 229 image
    @Benjamin_Dellal As @mbartlett21 mentioned FeatureScript features cannot be used in the assembly. If you post an example or give us more details we may be able to help find an alternative.
    Have you tried the replicate command in the assembly?
  • Benjamin_Dellal
    Benjamin_Dellal Member Posts: 8 PRO
    My problem is the following:
    I have an assembly that is using 100x the same part. I am currently in the process of migrating our CAD model from our Catia platform to Onshape.
    In Catia, I am cheating: I made a single part, in a single body and used "user pattern" to replicate it based on a point cloud that sets their positions. I manually correct this on the BOM later.
    I can not find any good way to do the same in onshape.
    • I cannot import my sketch containing the points. Points just do not show up. So, I cannot use point pattern in Onshape.
    • Importing the catia model as is, Onshape just makes 100 different parts out of the 1 original part
  • tim_hess427
    tim_hess427 Member Posts: 648 ✭✭✭✭
    When you've tried to import the sketch - is that using the DXF/DWG import tool in the sketch environment? It seems odd to me that the points wouldn't show up. Maybe its a bug?
  • TimRice
    TimRice Member, Moderator, Onshape Employees Posts: 315 image
    edited November 2018
    What format are you attempting to bring the sketch into Onshape? Only dxfs can import sketch geometry. If you can export just the unique part from Catia as well as the points in a dxf this should be a simple job to setup in an Onshape assembly. The BOM would be correct as well.
    Workflow: Import catia part into part studio. Import dxf into a second part studio, add a mate connector at each point. Bring the sketch into an assembly and mate part to mate connector at each sketch point.
    Onshape, Inc.
  • Benjamin_Dellal
    Thanks guys.
    I found a decent work around for now:
    The part that mates to all 100 parts has locating holes for these. After constraining one instance, I can use the replicate command as if my parts were screws.
    But, I still need to find a better way and using the point pattern in as assembly would be ideal.
  • TimRice
    Currently FeatureScript cannot be used in assemblies and only in part studios
    Onshape, Inc.
    @Benjamin_Dellal depending upon how you mate your first part, you should be able to select “all edges on face” (or similar) in Replicate to do it all in one go.
