Callout Balloon to identify a part configurations
AuroraRonAuroraRon Member Posts: 141 PRO
How can I identify what configuration is being used in a drawing? I would have thought I could use a call-out (balloon) to identify it but its not an option.
  • AuroraRonAuroraRon Member Posts: 141 PRO
    edited November 2018
    I have tried in Part Configuration to edit "Configured Part Properties" and.using a field such as "Project" so each configuration has a different Project Name.   In the drawing I create a callout/balloon and try to have it display the field "Project" but it only displays "---"
  • mthiesmeyermthiesmeyer Onshape Employees Posts: 115 image
    @AuroraRon
    You cannot directly callout a part's configuration at this time, please make an improvement request if you would like to see this functionality ---->
    Your second approach should work. Can you please provide a link to a document where this is not working? Or open a support ticket if you cannot make your document public.
    Thank you,
    Mike
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,063 PRO
    Works for me.
    Can you link your document?
    Found the problem. In "configured part properties,  "engine" and "alternator" did not match a part configuration so the bubble/call-out displayed "---"
    Must pay more attention the table!   Took a fresh look the next day to realize it.
