Problem with tangent mate
Dmitry_Golovkin
Dmitry_Golovkin Member Posts: 22 ✭✭
Hello dear community,
In folowing design it does not animate correctly.
For some reason the pin going only by half of the ring.
Any advice wold be appriciated.
https://cad.onshape.com/documents/49687b05001ac414fda4f774/w/93dd33c533a805ec3e93e60b/e/c9d4c909bfe4c023123940b9
  • Dmitry_Golovkin
    Thank you Andy,
    Will be wating for the solution.
    NeilCooke Moderator, Onshape Employees Posts: 6,103 image
    I presume that pin is spring-loaded? Onshape cannot simulate a spring force so I believe that there will always be multiple solutions and therefore not solvable.
  • Dmitry_Golovkin
    It's not gonna be spring loaded. Actually it must be wheel instead of pin. Two shafts are not parallel so I made a slider mate to pin be able to stick to sliding surface otherwise in higest or lowedt position the pin could be too long or too short.
