Enclose on Projected Spline
famadorian
If I project a set of splines, can I not use these projected splines in the Enclose command to make a surface?
https://cad.onshape.com/documents/6e77b22afe1bdac02e427230/w/bfee167c8c62d3cbf9e2303e/e/66ae6513994178181b15a943
When you hover your mouse on the red text, it tells you a more specific error: "This operations creates intersecting edges"
If you look at your original sketch, the lines you've drawn are indeed crossing in the far corner. If you zoom wayyy in you can see the endpoints of that line are not coincident. You can make them touch by adding a coincident constraint (select two endpoint and press the I key). After that change the fill feature should work fine.
1
No - enclose is for making solids from surfaces and planes. You could create a plane through your line (normal to plane FRONT) and extrude the sketch up to that plane. The end of the solid would give you the face you need.Senior Director, Technical Services, EMEA0
Not sure what you mean. Is there a command to make a surface from a set of curves?
No - you can from a sketch, using offset surface, but not an arbitrary set of 3D curves. You can try the Fill command, but it may not work as you want it to,
Extrude example:
Senior Director, Technical Services, EMEA0 -
ok, but how do I approach this, then?
This is supposed to be a road with a wall alongside it
If you extrude the whole thing as a solid you will get the face marked "1" (as in my image). Or try Fill.Senior Director, Technical Services, EMEA1
Fill was really what I meant to do, instead of that enclose command, but Fill gives me the message that it's not able to regenerate it.
I also tried to extrude the same set of spline, but that also gives the same error
When it says it can't regenerate, is there somewhere else that explains a little more what its problems are? That it can't regenerate doesn't really tell me anything to help troubleshoot.0
1 -
woah, I was sure I had restrained them;) Thanks a lot.kevin_o_toole_1 said:When you hover your mouse on the red text, it tells you a more specific error: "This operations creates intersecting edges"
btw, as I don't need the splines I used for projection, I thought I could just change them to construction splines, but that doesn't seem to work.
I don't really want them displayed cause I only use them to make the road. However, if I convert them to construction splines, the rest won't regenerate.
@famadorian you're quite the surfacing dude.
I've got $5 buck on "you'll succeed". Please keep posting progress.
1 -
Here's another way,
https://cad.onshape.com/documents/7bca6329d1065398cccf45d6/w/267c572473b967c7d8fb05be/e/1e0594d38604f3ef094647df
There's a million ways to build this and best way is to keep on trying. I tend not to project curves and sketches rather deal with the surfaces themself.
Neither way is right or wrong.....
billy2 said:Here's another way,
Right, but that's like constructing and then deconstructing harry;) I like to build a cage of splines and then just surface them in the end;)
I get it, working with wireframe, constructing surfaces, then enclosing to make a solid.
What are you making? What is this thing?
@famadorian
Is this what your looking for???
https://cad.onshape.com/documents/5daf6a7f162573f5c41ee31d/w/1c11412f7cf36bc020bf7083/e/646ece950fc5f5c533f3ed8d
Right now I'm going to make a lot for a house with underground parkingbilly2 said:I get it, working with wireframe, constructing surfaces, then enclosing to make a solid.
No;) The task has already been solved, but now the question is why I can't use construction lines insteaddick_van_der_vaart said:@famadorian
