Configuration Suppression Terminology
owen_sparksowen_sparks Member, Developers Posts: 2,660 PRO
Hi folks am I the only one that finds the configuration check-boxes counter-intuitive?
For something ticked we are stating "YES I want to NOT CANCEL doing something."
Wouldn't either "Enable" or "Suppress" be a simpler?
I've taken to calling them the "Yes we are having no bananas" boxes. :)
Cheers,
Owen S.
HWM-Water Ltd
    :+1:
    I also find the labels are fairly long compared to how long it is actually needed for the checkbox
    IR for AS/NZS 1100
    edited January 2019
    :+1:
    Good point. How about just "On" for the header and rotate the feature name 90deg? 🤣
    HWM-Water Ltd
    IR for AS/NZS 1100
    Yes! I have to think, right to go left, right to go left, right to go left every time
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,050 PRO
    We call that a Michigan left around here :)
    Funny how in SW it was "Check to NOT Use" but it kinda made sense as usually you will want everything on, except for the unique cases when you don't.
    Although Onshape does make sense if you just look at the pretty colors.
    White is "Off"
    Blue is "On"
    So visually it make more sense, but the usage of the word "suppressed" makes it tricky, as you tend to read to quick and forget there is an "un" prefix
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,255 image
    We thought a fair amount about this (that's not to say we got it perfectly right).  Our thinking was very much "we want a check-mark when it's on and an empty box when it's suppressed" and we didn't want to introduce a new term like "enabled" or "on" that didn't necessarily scream "suppression".
  • Cris_BowersCris_Bowers Member Posts: 281 PRO
    I'm guilty of always checking the box when I want something suppressed as well. The reason is probably due to years of using other software where "Suppress" is the action to take. I think this was done because default state is generally unsupressed so you would take no action. Using the "Suppress" header is asking do you want to take this action and if so check the box. As an alternative, a list box with a "U" for unsuppressed and "S" for suppressed would be an acceptable solution if one is needed. Then change the header name to Suppression State.
  • andrew_kleinertandrew_kleinert Member Posts: 97 PRO
    +1 for existing behaviour.
    I admit that I did get a tad confused when I first learnt about configurations and thinking about it ... but "thinking about it" was the wrong thing to do.  When I turned the brain off it flowed a treat.
    White is "Off"
    Blue is "On"
    Totally this! :)
    Cheers,
    Owen S.
    It's probably a bit of a limitation of the English language.
    We can freely toss around opposite terms like "open" / "closed" without being confused by double-negatives.  ie: to have a checkbox that indicates that something is not opened, then there is a choice between:
    (1) Label it "Not opened" which would confuse people in the way you have described.
    (2) Label it "Closed" which avoids all confusion.
    But when opposite terms are formed using a negative prefix like "suppressed" / "unsuppressed" then it can lead to this double negative confusion.  All the more so because traditionally in English a double negative is a positive ("I am not unhappy") but slang forms make it a greater negative ("I dunno nothing") as does the influence from other languages like Spanish ("Yo tengo nada" / "Yo no tengo nada" are both negatives)
    Maybe instead of using the term "Unsuppressed", it could have been rendered as "Suppressed" instead?  That's probably more confusing.
    This is probably one of those situations where the best solution was the least worst option! :)
  • lucas_johnson222lucas_johnson222 Member Posts: 5
    :+1:
    I completely agree, I would vote for "On" to simplify and shorten things. Thanks!
