Frame text box
Asgeir_SætherAsgeir_Sæther Member Posts: 2
Hello, i am quite new to oneshape and having troubles removing the frame om the text box. it apears on the drawing when i do a printout. Can anyone help me here?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,026 PRO
    Can you give a screen shot or a photo of what you mean?
    Text boxes don't have frames.
    Are you using a table with one cell to create a text box?
    Or is it a dimension?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,952 image
    Or is it sketch text? If it is, then this is meant for extruding to make 3D text. If it is a true drawing (not a model), then use the Note tool.
  • Asgeir_SætherAsgeir_Sæther Member Posts: 2
    edited January 2019
    Thanks, that solved my problem :)
