Boolean Intersect with MESH
john_mcclary
Member, Developers Posts: 4,052 PRO
The end game is to convert a MESH into a solid.
By using a boolean intersect to create a part, that should let us pick and choose pieces or sections of a mesh to convert.
Rather than having it attempt to convert an entire mesh.
Also that would allow us to purposefully ignore some parts of a mesh that we know are too complex to convert. (Self intersection errors from a bad scan for example)
This is lieu of manually creating sketches and tracing / extruding from a mesh, for a more streamlined workflow.
Is this mesh-capable boolean public somewhere?
Thanks.
@lougallo
@john_mcclary
Here is a Boolean FeatureScript that I put together that supports solid parts, surfaces and meshes (I just updated it to support meshes).
https://cad.onshape.com/documents/84d939daceef6a928b8abcba
@lougallo
When has Onshape supported booleaning of meshes since?
IR for AS/NZS 1100
HWM-Water Ltd
No, there's currently no way to adjust that.
