Replace Assembly Request (improved Replace Part function)
New feature request:
The function "Replace Part" is available in onshape.
But I would also like to be able to replace an assembly, with an assembly.
More ideal would be to make no difference between parts and assemblies in this case of replacement.
This are all the possible cases i think:
1. replace a part with a part.
2. replace a assembly with a assembly.
3. replace a part with a assembly,
4. replace a assembly with a part
The main reason to use a "replace function" is to keep the assembly mates in the main assembly.
(Otherwise a "insert" action for the new, and a "delete action" for the old would work.)
IR for AS/NZS 1100
PS:
But i just followed this link in the above blue box:
"Please submit support tickets for bugs but you can request improvements in the Product Feedback category."
@lougallo
Should this be changed?
IR for AS/NZS 1100
