Extrude in non-normal direction - workaround.
romeograham
Member, csevp Posts: 733 PRO
Anyone that is coming from SolidWorks may be used to using the "extrude direction" capability in Extrude features: you can select a direction that is not normal to the sketch's plane for the extrude.
I was trying to figure out how to do this in Onshape (but there isn't that exact feature).
I stumbled on a work-around, using a temporary body / sketch.
Turns out that an extrude feature will go in the direction normal to the first sketch / face selected. Then you can select a different sketch / face, and it will be extruded in the same direction as the normal of the first sketch:
Sketch 4 (on my "Line of Draw" plane) is selected first. Then Sketch 3 is selected. This is the body that I really want in my model. You can see the body extruded from Sketch 3 goes in the direction I'd like, but originates from a different plane.
This could save using a sweep or other combination of features to achieve the correct geometry. Combined with a draft in the Extrude, it reduces the number of features required for some types of geometry where the Line of Draw is not necessarily normal to planes / faces in the model.
For the extra seed extruded body, you would have to delete it after this feature. For Subtract or Intersect extrudes, the "seed" body is not created, and doesn't have to be eliminated after you're done.
Does anyone have a FeatureScript that allows an "extrude in direction" option?
I created an IR a while ago, but now can't find it....
Thanks
Romeo
Thanks
Romeo
3
That's perfect! works just like I hoped.
Why oh why is not part of the default Extrude command?
Thanks!
You can also use this feature (It has a thin-feature option as well)
https://cad.onshape.com/documents/24819ddab7dc83c810eb8246
IR for AS/NZS 1100
To answer your question, we are always fighting an uphill battle of simplicity vs. robustness. We haven't heard a lot of people asking for extrude direction selection, so it's not worth making the extrude command more complicated for a use case that people haven't expressed interest in.
If a direction selection is added to the extrude command, will we then be able to select non-planar faces to extrude and non-sketch edges?
IR for AS/NZS 1100
A sweep wouldn't be able to do that without a separate feature.
here is the closest IR I found - please vote!
https://cad.onshape.com/documents/95b6b10616fa81d9419fcdd2/v/5e7ee41b4f8366b40b835f1b/e/c29448656f30372b1d04a5f7
Twitter: @onshapetricks & @babart1977
https://forum.onshape.com/discussion/11235/option-to-extrude-along-vector
OMG I googled this thinking I was being narrowminded for missing this. Has this been added in yet?
It was over 2 years ago:
Improvements to Onshape - February 3rd, 2023 — Onshape
There's now a "direction" option in the extrude tool (been there for a while)…
