New to parametrics: how do I make a basic cube controlled by one dimensional value?
Made a centerpoint rectangle. set a side dimension to 50mm. added an equal constraint to a perpendicular side.
Now I want it to extrude to the set 50mm dimension. If I change the dimension, the cube will scale equally.
I must be overthinking it. Best practices?
traveler_hauptman Member, OS Professional, Mentor, Developers Posts: 419 PRO
Best practice would be to use equations to establish the relationship. Equations functionality is not released yet. Until then, you have to use a hack.
While I wouldn't typically use a hack for production work, it can help you get more familiar with how things (currently) work. Points for the most creative one....
1 -
The non-creative version: https://cad.onshape.com/documents/2149057fbe6c410e9a3e4746/w/bb0d56bee3f14f61ae5d0173/e/d258de12d5194b3e95fff205
5 -
When you project from one plane to a perpendicular one, all the projections end up in a line... but that's ok because we only need the one line.
Coincident mates on the shared edge work fine as well.
5 -
jakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 665
I would use a sweep with the system as is.
1. Sketch a center-point rectangle and make the lengths equal to be a square. Dimension the square, this will be the dimension to drive the cube size.
2. On an orthogonal plane, sketch a line from the center of the rectangle that is perpendicular to the rectangular face. Select this line and choose it to be equal that of the rectangular line.
3. Sweep the square face along the perpendicular line. This should create a cube.
From here you can go back to sketch 1 and edit the dimension. The cube should update accordingly.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com7
