How to Import multiple Parasolids/STL/Step files into an Assembly
joshua_gibson
Member Posts: 3 ✭
in General
I have multiple Parasolid files that I would like to make an assembly with to see how the parts fit together. Is there a way to do this in Onshape?
I tried inserting the Parasolid into an assmebly but it wont allow me to. If I select the Parasolid I want to insert the green check mark stays dimmed.
NeilCooke
Moderator, Onshape Employees Posts: 5,992
I can see you have imported a Zip file. You only need to do that for Solidworks, Creo, Inventor, Solid Edge or Catia files. Parasolid files and other neutral files like STEP should not be zipped up.Senior Director, Technical Services, EMEA5
As they said on Mythbusters "There's yer problem!"
@joshua_gibson it looks like your Parasolid might be an STL or other mesh, not an actual part.
O.S.
HWM-Water Ltd
