Lofts. Please help a novice
bill_woodbill_wood Member Posts: 12 ✭✭
Front plane circle : 2.375 dia
Plane 1 cirlcles: 2.30 & 1.375 dia
Plane 2 circle: 1.30 dia
Planes offset 1"
Want to loft from Front Plane to Plane 1 Larger Circle & Loft from Plane1 smaller circle to plane 2
Onshape will allow a solid from plane 1 to plane 2, but only a surface from Front plane to Plane 1
What am I doing wrong?
Thanks in advance!
    Make sure you are selecting the shaded area (region) to make a loft solid. Selecting the circle edges will create a surface.
  • KrzKrz Member, Developers Posts: 68 ✭✭✭
    As Onshape warns you: you cannot use faces or regions with inner loops as profiles for loft.
    You need 2 sketches on Plane 1: one for first loft and one for second loft.
    G
    M
    T
    Y
    EnglishPolishSwedish
    Text-to-speech function is limited to 200 characters
  • bill_woodbill_wood Member Posts: 12 ✭✭
    Thank you, that worked!
