Y-Axis Up selection not remembered when updating imported parts
Cris_BowersCris_Bowers Member Posts: 281 PRO
I had to create some plate letters aligned to a curve in Solidworks because of the lack of fonts available to Onshape. It took some playing around with to get everything aligned so I had to re-import a few times. Well when I re-import I don't get the Y-Axis Up selection and apparently it doesn't remember as the parts ended up coming in aligned to the Top Plane instead of the Front Plane.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,050 PRO
    If you right click on your import and edit:
    You can change the source axis any time
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,985 image
    That is true - you will have to create an IR to get Onshape to remember the Y axis direction. Don't forget, you can also edit the import feature to change the Y axis direction at any time.
  • Cris_BowersCris_Bowers Member Posts: 281 PRO
    Ah, thanks. I didn't realize I could do that.
