Segmenting a circle
john_doubleday
Member Posts: 58 EDU
Learning how to fly Onshape for a student Name Tag. Is it possible to delete part of an added circle?
If not, then you can modify the sketch plane of your circle to be that face any time.
then you can take advantage of sketch inference, which will create a zone wherever your sketch intersects something on the face you created the sketch plane. (yea that was wordy, easier to see than say )
As you can see, we choose Add, and only select the portion of the ring within the badge.
Then we set the depth "up to face" to make sure it follows the same depth of the main body.
From here we set the merge scope to include all of the pieces that intersect. (you could also have chosen "Merge with All"
