Macbook Pro hardware recommendations wanted: GPU vs CPU vs Memory & M370X
lars_rengersen
Member Posts: 32 PRO
Not using Onshape on a daily basis, but still quite often.
Hope you can think along what my best bet is in terms of Mac hardware.
I had a 2015 Macbook Pro 13" with only 8GB of RAM. Upgraded to a 2015 Macbook Pro 13" with 16 GB RAM.
That one now has a hardware failure so I can only use it with external keyboard and mouse.
It isn't very fast and it only has the Intel Iris 1.5 GB GPU. So my question is, what do I do:
1- Revert back to the 2015 Macbook Pro 13" with only 8GB of RAM and add an external video card (eGPU)
2- Upgrade to the 2015 Macbook Pro 15" with 16GB RAM and dual GPU (Intel Iris Pro + AMD Radeon R9 M370X)
- other....
I'm not really a fan of the newest Macbook Pro's (overpriced, in my view lower build quality, inferior keyboard due to less key travel) so that's why I prefer to continue using the late 2015 models.
I am using parallels to run some Windows applications, so that votes for 16 GB RAM.
So I am currently leaning towards option 2.
Anyone else using Onshape on a 15" Macbook Pro with AMD Radeon R9 M370X?
- other....
My current MBP2015 (with the broken keyboard) and only the Iris GPU gets:
So from your message I take that that isn't that bad either.
Main reason for changing machine also is the broken touchpad/keyboard but it's nice to also see some GPU improvement while doing so.
By comparison, my 2018 MBP with AMD Radeon Pro 560X is 29.9 million triangles, 244.3 million lines.
Can anyone else post results to check?
Bottom line is 465 million triangles/sec and 250 million lines/sec.
Your browser is compatible with Onshape
Browser
WebGL and extensions
Renderer
Performance check
WebSockets
Geographical data
I am a bit puzzeled by the results:
Iris GPU active
Triangles per second = 185 million
Lines per second = 65 million
AMD GPU active
Triangles per second = 20 million
Lines per second = 106 million
I had expected both figures to be higher with AMD. Overall performance indicator seems similar. What is the difference between the two measurements?
And is the AMD situation indeed preferable?
We are working to get closer to the root cause of the issue to see that either the driver problem is resolved, or a suitable workaround can be applied.
Twitter: @onshapetricks & @babart1977
Any advice?
Are you experience performance issues while using the application? Or is the issue with the numbers on the performance check page? If you're experiencing issues in the application itself, I would suggest filing a support ticket so we can dig in further.
before with the IRIS graphics: 130M triangles, 54M lines
after with the eGPU: 13.5M triangles, 220M lines
It seems to be better, but I need to use it a little more. I just would like some guidance on whether this is a good solution or should follow another strategy.
Any help would be greatly appreciated.
Your solution is worth while, though not easily validated by the performance check page.
One caveat to that is that a more powerful GPU will only help performance for GPU-related things, such as rendering and selection. Other performance issues can arise when using many tabs simultaneously (bandwidth constraints, CPU contention, memory constraints, and synchronization).
Back then I bought another 2015 Macbook with a Radeon gpu.
In 2020 when Apple improved the keyboard I bought a new Mac.
it feels like a flexible solution to buy a Razer X Chroma enclosure https://egpu.io/razer-core-x-chroma-review-absolute-unit/
So my question is: what kind of GPU do I need for Onshape?
Apple only supports Amd so that is easy https://support.apple.com/nl-nl/HT208544
There is a lot to choose
https://www.tomshardware.com/reviews/gpu-hierarchy,4388.html
Will a Vega 56 or 64 already make a huge difference?
Or is it better and spending a bit more om a Rx5700XT or even a 6xxx series?
Thanks!
