How do you 'update' subassembly in main assembly within same document?
bruce_williamsbruce_williams Member, Developers Posts: 842 EDU
I built partial sub-assemblies and inserted them into a main assembly.  Now after adding parts, mates, etc. in the sub.  the main is not getting all the mates.  Am I missing an update step somewhere?  Or other suggestion?  I am attaching pictures of the sub and main.
www.accuratepattern.com
  • Cris_BowersCris_Bowers Member Posts: 281 PRO
    edited April 2019 Answer ✓
    Just suppress and unsuppress your group mate in the main assembly. Should fix it. It's one of those things that should really have attention called to it.
    @Cris_Bowers
    that is it!  thanks for quick answer.
  • rune_thorsen229rune_thorsen229 Member Posts: 182 EDU
    Cris_Bowers, just had a similar problem. I expected there should be a 'update' somewhere.
    P.S. After doing the suppress/unsuppress I got a diamond and something about negative impact on performance. What ???
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,031 PRO
    Yea, that's a known problem with group mates and sub-assemblies... Try to avoid doing that if you can.
    As for your diamond and negative impact.. Do you have a screen shot of it? I can't remember ever seeing something like that
    john_mcclary, you explained it very well so I copy it here for others to enjoy: "if you feel the model being slow from spinning the view around, then you can lower the tessellation by right clicking the part and setting use automatic tessellation. it is purely graphical, the model will still export with the same precision."
    What's that got to do with "How do you 'update' subassembly in main assembly within same document?" ;)  :-1: ??
    O.S.
    HWM-Water Ltd
