Variable
D_7D_7 Member Posts: 12 ✭✭
Assign Variable for the entire PartStudios in the Document...
    Please see this IR:
    Cheers, Owen S.
    HWM-Water Ltd
    @D_7
    A good workaround for now is to write a custom feature which sets all the variables, and then call that custom feature at the beginning of each part studio:
    https://cad.onshape.com/documents/4bcc69a118838dd41e979713/w/19539881356ff2f22ff15dd8/e/5fca1275e609277a3b90e253
  • D_7D_7 Member Posts: 12 ✭✭
    @Jake_Rosenfeld Can I Use It For Entire Document ???
    @D_7 yes, just use the custom feature as the first feature in each part studio in your document
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,063 PRO
    Not in assemblies though.
    Actually it's better than that.  If you want some really-really-global variables you can use it in multiple documents, for anyone you care to share the featurescript with, so you could in theory use them across the planet.  (Though you'd need to revision the FS source doc and then update the FS in the target PS if you change the variable value and that would update anything that used the feature.)
    Owen S.
    HWM-Water Ltd
  • brian_bradybrian_brady Member, Developers Posts: 505 EDU
    @D_7
    A good workaround ...
    Sorry, but no such thing as a "good workaround." If it was "good" it would be the correct approach, not the "workaround." Onshape really, really, really needs to separate variables from the feature tree. That way they always exist as if they were created before anything else. The only precedence needed is the order of the variables. If variables existed outside of the feature tree, then they could be assigned to sketch dimensions on the fly as well.
    edited April 2019
    @brian_brady
    Actually I think Onshape's approach is a better method:
    Because it is a feature, you can move it down your history tree, or add multiple featurescripts, and configure part studios by just suppressing/unsuppressing the global variable features.
    Because they are like any other variable. you can override each variable independently at the part studio level by defining a local variable with the same name, then having it below the global feature in the tree.
    I do this for sheet metal often, I'll have 2 variables (thickness & bendradius) then insert them before a sheet-metal feature, then I can quickly modify all the sheet-metal in a project by just removing an override, or dragging around the feature higher in the tree to influence more parts, or modifying the featurescripts.
    example:
    https://cad.onshape.com/documents/ad3a9824a02b9066da33b369/w/bb566cc2750ad4ccc29f90ce/e/41bd476940542832f1fcb98c
