Derived Assembly
famadorian
famadorian Member Posts: 390 ✭✭✭
I figured out I can't do boolean operations in the assembly, so I would have to use derive in the part studio, but the part studio cannot derive assemblies, as far as I understand;)
I have inserted a sink assembly on top of cabinet assembly, but the cabinets would have to be cut to not stick out of the sink;)
  • owen_sparks
    Have a look under "edit in context".  The help files and video will explain it far better than I can.
    Cheers, Owen S.
    HWM-Water Ltd
  • famadorian
    Cheers, Owen S.
    , but this in-context editing changes the part, while I just want to change this specific instance of the part
    I don't want to cut the actual part in the part studio; only this instance which has to fit with the sink
  • owen_sparks
    Well put John.
    HWM-Water Ltd
  • famadorian
    Use in-context as @owen_sparks said,
    but create a new part studio in-context instead.
    then select the transparent part you want to create a special instance for, and select "Transform" and set it to copy in place.
    that will give you a new part in-context, then you can trim your cuts, and replace the existing part in the assembly with this new one.
    OR
    you can create a configuration in the original part instead, and have the one configuration in-context
    Ok, that went over my head;)
    1. click edit in context
    2. create a new part studio while in-context? (that somehow brings me out of in-context edit mode)
  • john_mcclary
    Instead of right clicking a part, then saying edit in context.
    While in the assembly, click this button
    That creates a blank part studio, that has a phantom assembly in it.
    Any part you do a "Transform, copy in place" to will create a new part in that position.
    So you would do that to the new part you want to make. (or parts) Then you can boolean subtract them, or whatever modifications you need to make that reference another part in the assembly
  • malay_kumar
    malay_kumar Onshape Employees, Developers Posts: 93 image
    In this case, if just one instance (or a subset of instances) are to be cut for assembly then creating a config, defining cut features in-context and configuring suppression states of cut features is probably best choice.
    Another option would be to replace the instances with a derived part and then doing in context to create cut. Derived part approach will be better if there are lot of features to be configured.
    Creating the new in-context part studio will require to replace the part but then it will not be updatable.
  • famadorian
    Ok, bear with me;)
    I learned to "Create part studio in context" today and I created a part to fill where there were no cabinets;) Love it. Thanks. I also created an in-context modification to the cabinet.
    However, I don't understand how to proceed with the original question, which was to trim all cabinets with this sink.
    You told me to "Transform, copy in place"; is this a single command? Is it a button somewhere?
  • john_mcclary
    Transform is a button in a part studio, copy in place is an option of transform.
    By doing a copy in place, it creates a new instace of a part you can add/remove features to.
  • Jake_Rosenfeld
    Here is the help page for the Transform feature:
    https://cad.onshape.com/help/Content/transform.htm
    As John mentions, one of its options is to copy in place.
  • famadorian
    Got it now;) Thanks.
    However, this results in static parts which won't update if I change the sink.
    I've tried to read over and over malay_kumar response, but I can't parse it;)
    Is it possible to have dynamic parts which can dynamically change based on the sink suppressions?;)
  • john_mcclary
    if it is in-context, it should be dynamic.
    You will need to update the context if you make a change in the assembly.
    Right click the part in the assembly, or go to the context in the part studio, and select update
  • Cache_River_Mill
    Cache_River_Mill Member Posts: 225 PRO
    We had trouble updating cabinet in assemblies as well. We also had trouble using configured assemblies in drawings. Here is what we created for our cabinets for now.
