Sheet Metal - Flange Manilupation
Jake_Rosenfeld
Moderator, Onshape Employees, Developers Posts: 1,646
@POC
You can use the Move Face feature to make edits like this:
https://cad.onshape.com/help/Content/moveface.htm
The top one is easiest, you can move face using Up To Entity as the End Type, and select the side face of the bend, or one of the vertices of the side face of the bend as the up-to entity.
The bottom is a bit trickier, you probably want to push the side face of the bend inwards be using move face on it, and then see how the flange reacts?
Usually for these things it is best to post the URL of your document so that we can actually go in and try things out:
https://forum.onshape.com/discussion/9107/forum-post-checklist
Jake Rosenfeld - Modeling Team5 -
john_mcclary
Member, Developers Posts: 4,043 PRO
#1: Move face is good for that, otherwise an extrude cut
#2: You can set the gap in the sheet-metal base feature
Any parameters here will be maintained for all additional flanges/features
7
