Edit company properties
ArtmAkimArtmAkim Member Posts: 5
How can I edit and delete company properties?
The only possibility is to make property active/inactive. I can't delete any custom or my propeties.
Also there is no way to delete values in List-type propertie.
Is it normal or I'm doeing something wrong?
And also by clicing button "contact support" nothing happens. It doesn't work by me.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,991 image
    Hi @ArtmAkim properties that have previously been Active cannot be deleted or have existing content modified. This is because existing Documents may be using those properties and deleting them would break/invalidate those designs.
    For the "contact support" issue - do you have any AdBlockers running?
  • ArtmAkimArtmAkim Member Posts: 5
    Ok. Do you plan to add some instruments to edit activated properties?
    It is annoying. If I mistakenly add some value to the list of values, then it will remain there forever
    Not as far as I know - if you do contact support (support@onshape.com if you can't get "contact support" to work) there may be a way for them to do it, but I'm not sure.
  • M_BrehmM_Brehm Member, pcbaevp Posts: 7 PRO
    +1
  • N_MillerN_Miller Member Posts: 4 PRO
    The closest I got was:
    -Mark property I want to delete as "Inactive"
    -Change the name of inactive property so I can re-use the name in the updated property I am creating
    -Create new property to do what I want it to do
    -Edit new property in every part
