Control project(use) direction or alternate technique?
laird_broadfield
Member Posts: 42 ✭✭
I'm struggling to control the direction of the project(use) function -- and it's more confusing because I'd swear that 8 times out of 10 it works one way, and 2 times out of 10 it works the other way, and I can never figure out how to reproduce the 2of10 way.
This is my demo of the issue. (https://cad.onshape.com/documents/27349a7d22794a6a993806f6).
Across the middle is the Top plane, with a circle sketched on it. There's a line-angle plane at 45 degrees. I've created a sketch on the angled plane, and projected the circle from the first sketch. What's happened is what happens nearly all the time; it's been projected along the normal from the sketch plane.
What I often want (and I think happens occasionally, but I can't figure out how) is to project it normal to the projected entity's plane. That is, in this case, the projected oval would be directly "above" the origin entity.
How can I make this happen? Is it a specific order of operations with project(use), or is there some other technique I should be using?
Thanks.
Thanks.
Sorry for the belated reply.laird_broadfield said:
Okay, I found "Hide" (I haven't used surfaces enough to realize they are independently hide-able.) Will the hidden surface have any effect on the final part?
Sorry: "use a delete part" -- could you expand on that?
We have a feature called delete part. This will parametrically delete the part at that instance in the feature tree. This works because when the sketch is computed, the surface/part exists and then it is removed after that.
1. Select the delete part feature
2. When the feature opens, select the surface/part. This will delete the part when this feature is computed.
3. This leaves you with a projected edge and no surface.
When you go to edit the sketch that his projection has, you will see the surface still exists there. That is because the delete part isn't computed until after this sketch.
Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5
Sketch entities are always normal to sketch plane.If you project a circle,it will be normal to sketch plane.To get a projected sketch normal to projected entity, your sketch plane should be parallel to projected entity's plane.
In your case if you want a circle in the angled plane which is related to circle drawn in top plane then you have to revolve the circle drawn in top plane up to 45 deg. then you can project the entity.
I would probably extrude as a surface up to that sketch plane. That should give you an edge that you can project that should give you what you want.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com0
Narayan_K said:Sketch entities are always normal to sketch plane.If you project a circle,it will be normal to sketch plane.To get a projected sketch normal to projected entity, your sketch plane should be parallel to projected entity's plane.
Ah. No, I want the oval, not the circle -- but I want it as-seen-from-above. IOW, if I drew a normal line from the original circle's center point, it would pass through the center-point of the projected shape.0 -
Okay, did that, got an edge, projected the edge into a new sketch:jakeramsley said:I would probably extrude as a surface up to that sketch plane. That should give you an edge that you can project that should give you what you want.
That's the circle I want -- how do I get rid of the extrusion without leaving my new circle dangling?
That's the circle I want -- how do I get rid of the extrusion without leaving my new circle dangling?Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com0 -
And just to anticipate: I know I can delete the extrusion and remove the projection constraint... but that uncouples new-oval from first-circle, so that edits to first-circle are no longer carried through. At that point, I might as well get my lead pointer and pounce bag out. :-)laird_broadfield said:That's the circle I want -- how do I get rid of the extrusion without leaving my new circle dangling?0 -
Sorry: "use a delete part" -- could you expand on that?0 -
Projection seem to be working for me.
I'm sketching on the 'right' plane and 'use' the bottom of the cylinder which is being projected onto the 'Right' plane:
The project is normal to a sketch plane, not sure it should be otherwise. If you want to change this projection, change your sketch plane direction:
Now, the extrude direction is an improvement needed:
Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5 -
Got it; thanks. Hadn't yet had occasion to use that; now it makes sense.jakeramsley said:
1. Select [...]0
