Show 3D Model on Windows Form in .Net (C#)?
owen_sparksowen_sparks Member, Developers Posts: 2,660 PRO
edited August 2019 in General
Hi folks.
Is anyone aware of a .NET Windows Forms Control that can display a 3D model?  (Step Parasolid etc.)
Ideally all I want a user to be able to do is spin the model round and zoom.
There seem to be a bunch of widgets to design models in forms but I'm looking for a lighter viewer if possible.
Plan B is prerecorded spinning animation in a media player but that seems like a bit of a bodge.
Thanks all,
Owen S.
HWM-Water Ltd
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,988 image
    Can't they just use a browser and view the Onshape model?  :D
    edited August 2019
    Sure, I'll just need to put IR's into you good folks to cover the Automated Job Routing, Label Printing, Firmware Upload, Functional Testing and the like.  No rush, any time before next Friday is just fine...  (I want a singe application do do all things for all users.)
    In all seriousness the correct way would be using your API to a configured assembly but I'm looking for something simpler for the first iteration.
    Cheers, Owen S.
    HWM-Water Ltd
    @owen_sparks
    I did a search and found a few collada .net viewers.  Could you export as collada and use that?
    Thanks @Jake_Rosenfeld, appreciate you taking the time to have a look.  I'll go and have a read.
    Cheers, Owen S.
    HWM-Water Ltd
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,058 PRO
    I haven't tried yet, but WPF C# will let you view STL or OBJ
    Thanks @john_mcclary, as it happens I'm looking at my first WPF tutorial at the moment.  (Damn-it, I almost know what I'm doing in winforms and am back to the "Hello World" stage  :s Oh well it's the future....)
    Thanks fella,
    Owen.
    HWM-Water Ltd
    edited August 2019
    On the plus side it makes featurescript look a lot more readable :p
    HWM-Water Ltd
    Yea, when i went WPF it was a little wierd, but once you learn it, it's very simple.
    Doesn't do everything forms can, but you can always add that dll too :)
    Groovy, thanks for the reassurance that all will become clear :+1:
    HWM-Water Ltd
  • Gideon_PaullGideon_Paull Member Posts: 3 image
    A few years ago I created a project using WPF and C# for viewing 3D models. I'm pretty sure I used a library that I downloaded that read in and allowed you to manipulate OBJ files and even create assemblies out of them.
    When using WPF don't think of windows forms at all. It is really designed to be programed with the MVVM pattern where the View is separated from the logic of the program. It takes some getting used to.
    Thanks @Gideon_Paull it's interesting for sure. :)
    Was your application well received?
    Cheers, Owen.
    HWM-Water Ltd
