Clear or highlight selections which don't resolve
When a feature like a fillet has one of its selections go missing, every entity that was created by the original feature gets highlighted. This makes it difficult to see what is selected or not, as often much of the part will show as selected, instead of a few edges. I spend a lot of time going through fillets one entry at a time and deleting the selections which don't resolve.
Ideally there would be a one click button to clear all selections that don't resolve. An alternative would be to highlight them orange so they are easier to remove manually. Currently the only way to tell them from selections which do resolve is by hovering over the selections one at a time until the correct one is highlighted yellow.
    @connor_shannon510 Do you have an example you could post so I can see what specifically you are after?
    Is this what you mean?
    I am going to move and bug it.
  • michael_bromleymichael_bromley Member Posts: 110 PRO
    I've had that exact same issue, usually I just have to delete out my whole list of selections and start from scratch.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,028 PRO
    Same.  A clear button for missing entities would be nice.  Especially because you can't expand the window to see more lines. When every line has the same name it's hard to scroll and check which entries are bogus
