Surface to Part or Part to Surfaces or Delete Face problem
kai_h_borbe
Member Posts: 14 EDU
Good evening,
i need your help again. I finished my model, now i have to design the inlet and outlet.
At the first attempt, i choose Surfaces and only one part in the middle.
This model looks very good, but SimScale/OpenFoam likes no surface geometries. All geometries had to be volumegeometries.
If i delet the surfaces and do it with parts,as the in-, and outlet, but i got a problem, with the inner and outer wall.
But there is a "trick", told in the simscale forum, i can use the tool delete Face, to delete all outside faces, and only keep the inner faces.
But the tool it's not working, i choose all outside faces, with the option heal, to receive a part without any wallthickness.
Here is an example, what i mean: https://cad.onshape.com/documents/a8278b0f2a8c00e7372740e1/w/21a58331ceebc12a9fb0b0c3/e/3303500d6c6f0d0deeee0af5
I think to import the geometries to simscale, it has to be all parts, no surfaces. So maybe there are two roads to the goal,
Is it possible to convert the ten surfaces from the in-, and outlet, to two parts ?
OR
Why cant i delet the outside faces with the option heal, at the Help Manual i dont see any regulations.
Thank you very much
Kai
Twitter: @onshapetricks & @babart1977
Try a "delete face" with "leave open" and then a "fill". If the fill encloses a region, it will change the surface model to a solid model.
https://cad.onshape.com/help/Content/deleteface.htm
https://cad.onshape.com/help/Content/fill.htm
Edit: this will only work if the surfaces are all one surface model, rather than a bunch of separate surfaces. When creating these surfaces, is it possible for you do do an "Add" rather than a "New"? It would be helpful if you posted a link to your document so we can take a look.
