How to limit degrees of freedom in mates
robert_westling
Member Posts: 7 ✭
Is it possible to provide limits on movement in a mate? For instance, if you use a slider mate, can you assign values to the max distance a part can slide along an axis? The intent here is to be able to build assemblies where interference would limit the degree of freedom.
Thanks in advance for any assistance.
-robert
-robert
viru
Member, Developers Posts: 619 ✭✭✭✭
@robert_westling , Currently this capability is not available. In future we hope it will introduce by onshape
5 -
andrew_troup
Member, Mentor Posts: 1,585 ✭✭✭✭✭
Two things for future users who may bring this thread up in a search:
Firstly, the title is potentially slightly misleading as to the OP's question, because "degrees of freedom" has a different and important significance in motion control and analysis, rather than the notion the OP is seeking help with, the ability to set limits to movement along or about a particular axis.
An item which is unconstrained has six degrees of freedom (three rotational, and three linear translation); whereas a fully constrained (fixed) item has none. Mates are essentially ways of tying down some or all of these degrees of freedom, by aligning them with axes external to the component.
So: for those who want to see how to align particular degrees of freedom for a given component, I recommend this clip, starting 15m20s in:
https://youtu.be/ANfOBv-R2tQ?t=920
... And for those who on the other hand (like the OP) wish to set limits to motion, the good news is that, as of 08 AUG 2015, Onshape now has a "Limit" checkbox in all applicable mate types to do exactly that.2
You can also use RMB "Reset" on the slider mate and other mates. This is a great feature to get you back to your initial set position.
Twitter: @onshapetricks & @babart1977
