How would one make a pyramid shape?
HouseOfBreadCrumbs
Member Posts: 20 ✭
I tried searching online for an answer to this question before I asked the question but to no avail. There are some videos showing how to make a tetrahedron but my question is how to make a traditional pyramid with 4 sides (triangles) coming to a point and a flat bottom. The thing is though, I don't just want a pyramid shape per se, I am building something that I am actually going to have to create in real life, i.e. a pyramid out of a 3/8" flat acrylic sheet. Thus, each of the sides needs to be separate piece that I can cut and assemble together to form the pyramid. That is where I am having difficulty. Is there a way to create it so various calculations are done for me, such as the bevel angles to cut the triangles at? My project is here: https://cad.onshape.com/documents/be1cf4cd738c3fe03182dca4/w/64f757abb31dce8e28e63dc8/e/c68c9b9bb7b48446644542ca
You can see from the front of the object (where the orange part is) where I am trying to create the pyramid shape. Is there a way to make it so the edges line up neatly and bevel exactly as I need them to depending on how tall I make the pyramid?
Thanks for your help
NeilCooke
Moderator, Onshape Employees Posts: 5,970
Here is a one way: https://cad.onshape.com/documents/cd3c8ef577f5fcede867c16a/w/622dd075869747d78d2d1fd3/e/d884d7279efb1339842ee0e0Senior Director, Technical Services, EMEA6 -
NeilCooke
@HouseOfBreadCrumbs - just use my method. I've modified the model in the link above to make it rectangular (obviously the other two sides of the pyramid would be added in the assembly) - 14 features.
Senior Director, Technical Services, EMEA7
- Sketch rectangle
- Extrude pyramid using 'Draft' checkbox
- Shell to proper material thickness
- Create planes with line & angle on corner
- Split using those planes
- Remove unnecessary parts
I'm sure there will be a contest to make it with fewer features and end up with parametric feature script to make any pyramid in seconds. But this was the first idea I had when thinking this shape.
HWM-Water Ltd
I'm trying to follow your suggestion but can't quite seem to get it.
1. Sketch a square
2. Extrude using draft checkbox
3. Shell to proper material thickness... do I select all the faces? I don't understand what do to at this step.
Also, if I use a rectangle that is not a square then drafting does not form a pyramid shape with all faces coming to the same point. Instead it looks like this:
HWM-Water Ltd
https://cad.onshape.com/documents/b7a03380e6f81f03d5b40de7/w/f903f740ae0c0d2cfe4bd59d/e/2f7f4a6b2c1d13870b134f30
It's not 100% stable, and partially fails when you change from a 10x8in base to 8x10in base for example, because the internal face of the triangle changes from having 3 vertices to 4 and vice versa, which doesn't work well with the projected sketch on that face used for the loft.
It also leads to a slight interference at the peak when forcing the 4-vertices internal triangles to be a 3-vertices triangle instead, for lofting between internal and external triangle. (love the new interference analysis!)
I think @NeilCooke 's method is very elegant, but relies on the design having rotational symmetry. Is there a way to achieve the above non-symmetrical pyramid in a way that would be 100% correct and robust but still manageable in terms of complexity? I made an attempt trying to slice all sides using planes on a shelled pyramid, and while it might have been possible, it would have become quite unwieldy by the end of it.
Mind you I don't have a need for such a pyramid, it's more the technical challenge that interests me
Okay, yours does seem like the best solution, though surprisingly more complex than I would've thought it should be! As always, I appreciate the help.
https://cad.onshape.com/documents/b2c81db1fe30af018349a03c/w/5ccf5b61326982faea5c5d97/e/4c0626e0505912de7da21d4d
I know these threads tend to die a quick death but am curious about the model posted above. It seems like a simple pyramid template changeable in most all of its aspects. The rectangle base can be altered as well as the height of the peak's plane and location of the top point/vertex. Curious about what might be missing?
Thanks in advance
just to give my 2 cents - I think the OP is looking for parts for each side. On yours the parts overlap. I suppose you could skip the Offset surface features and do some trimming of parts to each other. I think Neil's solution has fewer features (although it is more advanced use of the tools).
