Small bug when moving documents (be aware)
3dcad
Member, OS Professional, Mentor Posts: 2,477 PRO
If subassembly tab is moved into new document - Onshape updates link and keeps main assemblies in good shape. That's great!
But if original doc is removed (send to trash) before manually accepting (from all the assemblies that use the linked part) part can't be accessed anymore. Open linked part just gives error that doc can't be opened from trash even though expecting link to point into new doc. Version update just shows empty list and there is no indicator of new versions.
Manual update to move reference into new doc.
If you bump into this problem and just see empty list while there should be newer versions available, simply restore doc from trash and do the manual reference update.
ps. It says that stuff will be deleted from trash after 30 days but I don't think that's the case today as I see way older stuff still hanging in trash.
//rami
2
