Change Standard Content from One Standard to Another
S_Regula
Member Posts: 95 PRO
Is there a way to change a standard content instance (or multiple instances) from one standard to another, ie from ANSI to ISO? I have an assembly with 50+ countersunk screws that need to be changed from ANSI #6-32 to ISO M3. When I right click on a single instance or select all instances with the same configuration, the only changes available are the Size, Head Type, Length, and Thread Length. It does not allow me to change the Standard, Category, Class, or Component (these are greyed out, see pic). If I use the "Replace Part" feature, the mates blow up. Seems like there should be a quick way of changing to avoid having to resolve all 50+ mates??
PeteYodis
Moderator, Onshape Employees Posts: 584
Sorry, missed your replace part comment. I'll create a ticket for you.5
Twitter: @onshapetricks & @babart1977
