If you would like to contact our Community Manager personally, feel free to  send a private message or an email.
Issue Opening Exported Files
                    Exporting drawings to PDF seems to work as expected, but I've been having some issues opening the exported DXFs and DWGs in other programs. Draftsight will open them fine, but Adobe Illustrator cannot. Illustrator can, however, open the DXFs created from sketches (not using the drawing package). Any thoughts on why this might be?
Another issue I'm seeing is that even if I open the exported drawing in Draftsight and save the drawing in format that Illustrator can open, the scaling is shifted ever so slightly (~1%) by doing this. A circle that was 2.00" becomes 2.02" This could be an issue with Draftsight or Illustrator and not OS, but it's still curious. Anyone seen something similar?
My intension would be opening customers dwg files and clean them up for export dxf to cnc. I'm sure 2013 format will be a problem.
Yes, 2013 format would be a problem for your use case. Thank you for sharing that.
I believe there are different export use cases where the most recent version is preferable, so to give you "export oldest version" we would either need to make 2 export DXF commands (old & new), or add a prompt for version to the existing export DXF command, which means the annoyance of one or two extra clicks when you export.
I welcome everyone's comments on those ideas.
But I'm sure Onshape needs to have separate settings tab for drawings in every case.
Not sure why, must be to do with how the splines are handled. Also not sure on which version we see a change over.
Twitter: @onshapetricks & @babart1977
@mechanical_cad ; It looks like you can explode the drawing views in the sheet tab, select everything in the sheet tab, do a ctrl+shift+c to copy from base point (0,0 used), then paste to whatever basepoint. Additionally, you may need to change the pasted item's color to "by layer" since it looks like the sheet borders are set to "not black", which looks like black but won't intelligently switch between black and white depending on the background color like black/white will. Hopefully the GIF below gets the point across better.
However, after playing around with DWGs from OS, I see a few issues. It looks like there is no 1:1 output option from drawings, so if you need to make edits at the DWG level, you will need to scale your modifications appropriately after being transferred over to the model space. Also, arcs and circles get output as multisegment polylines? This seems like it would have implications for laser cutting type operations. Further investigation shows that DWG exports from surfaces off a model export arcs as arcs, so why not drawings? Also, what can be done to get the colors to use what AutoCAD/Draftsight will understand as black/white by default?
