Engineering Revisions
Can anyone point me to how/if engineering revisions (X1, X2, ...) are used in Onshape? I haven't enabled revision management yet but in looking at it, it doesn't appear to have X1 revisions first prior to Release A/1. Anyone have experience here or recommendations for how they do this in their company?
bradley_sauln Moderator, Onshape Employees, Developers Posts: 373
@Jolls You can do so with the same revision scheme as long as you put them in the logical, successive order that you'd imagine them switching between. With the revision scheme you are allowed to 'jump' revisions to another valid one further down the line so in your scheme you should list out all possibilities: https://www.onshape.com/cad-blog/tech-tip-using-onshapes-custom-revision-scheme1
When you release something, the system will automatically increment to the next revision level, but you can over-ride it and set it to whatever you need.
Check out "Setting revision and part number preferences" section here: https://cad.onshape.com/help/Content/release_setup.htm
Twitter: @bradleysauln
https://forum.onshape.com/discussion/13395/advanced-using-release-management-pdm-and-a-plm-system-side-by-side#latest
-Andres
