Animated Assembly, Part Interference, and basic new user questions
dana_kelley262
Member Posts: 31 ✭
In the above document assembly is a linkage design. It animates fine but I have a few questions.
1. In the design are two short arms, Pivot Arms. These arms cannot drop below the axis points. Yet if one spins the large gear by hand or grabs another of the arms to animate sometimes the small arms drop below the their stationary axis. How is this possible?
1a. Adding rotational limits on the small arm's picot axis fixed the issue, well, I think it did.
2. Is there a tool to detect Interference between instances. Another way to ask, when two instances occupy the same space is there a way to detect it automatically? I notice a couple of linkages touching which may jam the linkage.
3. Somewhat Off Topic, Is there a tool to detect when two parts occupy the same space in the parts studio?
4. There are rotational limits on the large gear of + and - 1440 degrees. This sometimes animates and sometimes not. Why? or How is this done? And why can't it start from say -360 and go to 0? I would like to spin the gear in a selected direction to observe the results.
There is no collision detection when moving parts in an assembly, you will need to set limits.
If the model flips inside out, it can be caused by a number of things, some are mended by good mating practice, while others are just computer lag. Like the system is processing something in the background while you attempt to move something. Then the system catches up and over compensates the mouse input while sending to the server. Next thing you know it thinks you wanted the part 270° farther then you asked, then it calculates the rest of the part positions based on the new extreme movement.
Best to turn slowly until you get good smooth movement first.
You can see interference by right clicking the tree items
6
6
