How can I fix a loft twisting?
will_dyer
will_dyer Member Posts: 3 ✭
edited January 2020 in Community Support
I am trying to create a Loft between 2 sketches, but Onshape keeps twisting the shape around. I have tried matching vertices, but then Onshape just twists the other end, as you can see in the screenshots. The 1st and 2nd screenshots are the results when I match the rearmost vertices on each sketch, the 3rd screenshot is the 2 sketches I am trying to loft between, and the 4th and 5th screenshots are the result when I match the frontmost vertices on each sketch. Project linked here https://cad.onshape.com/documents/7b5c948934dab1717167f29c/w/8440194c5c881e91e0276d72/e/c5fa51d402d9f497174d247dvertices.
