Exercise Clamp
assane_fall
Member Posts: 6 EDU
I was doing Exercise clamp .but I can not get same results. its like there is something wrong with the data
Help please,Thanks
Welcome to Onshape!
That lesson has many sketch entities and constraints. It is more likely some minor detail like a constraint got missed (or added unexpectedly) while you were sketching.
Can you please post a link to your document and describe what exactly is not working for you?
Instructions of how to link your document are posted here: https://forum.onshape.com/discussion/9107/forum-post-checklist-read-this-first#latest
Looks like your document is private.
Please set it to public so we can view it
this is the Exercise,Thanks
@assane_fall - I don't think that is an exercise created by Onshape from https://learn.onshape.com ? - was it created by your instructor? Do you have a link to the exercise?
Senior Director, Technical Services, EMEA0 -
OK, I wasn't aware of that one - https://learn.onshape.com/learn/course/introduction-to-assembly-design/mating-parts/exercise-mating-parts?page=2Senior Director, Technical Services, EMEA0
You need to redo step 4:
- rmb > suppress all your mates
- unfix rod
- select front face of rod
- drag triad origin to center of face
- rmb > move to origin
- fix rod
- unsuppress mates
Senior Director, Technical Services, EMEA2 -
Hi guysWhy I can manage to Fastenen the arm and the grip ?Thanks
Just add a fasten mate to the center point of the grip's inside raidus and the handle's center radius.Then rotate twice to get it in final position
1 -
thank you very much I got it
