Advice
wayne_sauder
Member, csevp Posts: 649 PRO
in General
I need some help thinking through how to model this. https://cad.onshape.com/documents/1ab4bf82e8e3d62575bc4e6b/w/794b66bef9be88af3b028565/e/6bbceb06ae7b23a8334eecad
I need to do 7 rows of the stubs, the rows will be equally spaced down the tube vertically but the stubs need to be spaced 360 around the tube at varying spaces with each row being different. I started with patterns but it looks like a long job. Any ideas on a better method.
Are the stubs always going to be angled up like that, or do the stubs themselves change in each row?
I am imagining a very specialized custom feature that is like a point pattern, but actually a point around axis pattern, that allows you to pick a bunch of points and it will adjust the rotation correctly.
HWM-Water Ltd
https://cad.onshape.com/documents/c6c2c20a07b01fbd2dab54ca/w/097cd65800b9ce0f8d529808/e/3eef4488dccf29530bb735a6
