Setting parametric variable values from configuration table
ralph_stirling
Member Posts: 7 EDU
I have been using a lot of parametric variables to drive model designs. It has (finally) occurred to me that Configurations would be even better for a number of my parts. I would like to have configuration tables that can set parametric variables so I don't have to redo all my models to replace parametric variables with configuration variables. Reading docs and playing with the configurations tab has not yet revealed to me a way to do this.
For example, I have made a model for a generic syringe. I would like to have configurations for different size syringes (10mL plastic, 3mL plastic, 2mL glass, etc). Each size would have different values for #syr_body_od, #syr_body_len, etc.
The syringe model is at:
I suspect I have simply missed some simple and obvious way to do this.
Thanks,
-- Ralph
NeilCooke
Moderator, Onshape Employees Posts: 5,988
Does this work?
Senior Director, Technical Services, EMEA6
