Chromebook - Minor change
Hello,
I have been using the EDU version of Onshape with my classes, It is working very well, except for one snag. On a Chromebook, one has to tap two fingers on the track pad to bring up a menu. When using the Part Studio, many of my students accidently click "Delete" and see their work disappear. Obviously, they can just undo it with the "Ooops" buttons, but I wonder if it may be possible to move the DELETE option so that it is not quite as easy to click by accident.
    @andy_westthorp158 This is for any device that uses the two finger tap (or Snakebite click :smile: ).  Delete can be in the context menu when you are at the lower part of the screen. We have played around with this and will continue to look for solutions.
