Sketch Lines Not connecting
james_paquettejames_paquette Member Posts: 2
I have a sketch that i imported, but none of the corners are connected. How do I fix this?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,971 image
    edited March 2020
    For something so simple, measure it and redraw it. You would spend more time trying to fix it.
    Also, that imported profile has multiple entities on top of each other and is using splines instead of lines and arcs. Redraw it.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,043 PRO
    edited March 2020
    Neil is right,
    Easy way would be to create a new sketch and trace it with the proper line and circle tools. Then slap some dimensions all over it. Then delete the original sketch.
