Edit Dimension Formulas Directly Instead of Re-entering Entirely?
larry_hawes
Member Posts: 478 PRO
Is there a way to edit this dim without completely re-entering the formula? Let's say I simply want to move a parentheses? Or change a value? My intuition tells me I should be able to simply click in the formula and make changes but instead it seems I need to completely re-enter the formula. Must surely be missing something...Is it indeed necessary to completely re-enter the formula instead of clicking within it and change values?
https://cad.onshape.com/documents/8b9fe840a82dc6af6cbd24f9/w/4dc3501facf7c6436a6ac6e6/e/ec76a2da3ae7fa4dd17f7bb7
john_mcclary
Member, Developers Posts: 4,040 PRO
The text is selected text when you edit the field. If you just start typing, it will replace everything selected with whatever you begin to type.
Click again inside the text box, or use the left or right arrow keys to un-select.5
Can't say I've seen this behavior but i'll keep a lookout.
Sounds like similar behaviour - I wonder if it was caused by the computer OS somehow, rather than Onshape or browser.
