Help with an error
hagai_erenhagai_eren Member Posts: 2
Hi everyone,
I did a Patran 27 times and the site got stuck.
I get this alert:
Onshape encountered a problem with your last operation. If the problem persists, please contact support. Support code 8ec916c8fa827f0ea83dede4.
It's stuck like this for over an hour.
I did the same operation in another file and it got stuck too
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,950 image
    Use the Versions and History button (top left) to step through to a point where the model worked ok (9.42 am), then restore from that point. It's not a good idea to create knurled patterns like that unless it requires 3D printing. A better solution would be to create 1 complete knurl around the part (1mm height or whatever it is), then pattern that vertically down the shaft. This reduces the amount of processing and memory required to complete.
