align views from different inserted views?
otaolafrotaolafr Member Posts: 113 EDU
hello,
is there any way to center two views that we inserted separately in one drawing,
I have, for example, the right views of an assembly explode and not explode, and I would like to center the two views in the center of the page (the horizontal middle vertically aligned to the horizontal middle of the page)
is it possible?
best regards, franco
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,042 PRO
    No, you will need to eyeball it.
  • ross_macgregor429ross_macgregor429 Member Posts: 2 PRO
    I would love to see this feature, is there an update?
  • Shubham_MishraShubham_Mishra Member Posts: 4 PRO
    Hi @PeteYodis, when can we expect that? It would be very helpful in drafting work. It could save a lot of re-work efforts.
  • Ketil_VollandKetil_Volland Member, csevp Posts: 42 PRO
    Hi @pete_yodis, @PeteYodis
    I was wondering when this will happen. It is something that we have been waiting for a long time. When generation General assembly drawings with various named positions this would be very (very) welcome funtionality to have.
  • martienmartien Member Posts: 15 ✭✭
    I guess this hasn't yet reached a high enough priority to implement?
  • tom_augertom_auger Member Posts: 129 ✭✭
    Adding my voice / vote for this feature.
    • Select multiple views of different parts or assemblies
    • center, left, right, vertical center, top, bottom alignment options available
    • Choose one and apply
    Views are now aligned based on their bounds / bounding boxes
  • Also adding my vote for this feature.
    It is crucial for making correct drawings.
  • Chris_D_Mentes_001Chris_D_Mentes_001 Member, csevp Posts: 121 PRO
    Anyone got a link to the improvement request so I can vote up?
  • S1monS1mon Member Posts: 3,982 PRO
    This is the closest one I can find. Not sure if this reflects everything in this thread.
  • Daniel_SterlingDaniel_Sterling Member Posts: 4 PRO
    Adding my vote to have this as an improvement request. It's a simple right click operation in Solidworks!
  • martin_kopplowmartin_kopplow Member Posts: 1,217 PRO
    There already is a view alignment check box in the view property dialog. It can only suppress/enable alignment to the parent view, though. I wish there was an additional row of boxes that would enable X and Y alignment with a user specified reference view just in that place. I recently had to draw something similar to a ship's frame plan, and this option would have come handy. I have all the frames in their own view, and I need another view with them all layered on top of each other for the purpose of an overview.
    I could of course set up another assembly with all the frames and pull a single drawing off these, but I do already have all the views detailed out. Another use case is everything architecture, where overlaying the elevation of a set of walls and certain installations in the room may be desirable.
  • Mark_MacCabeMark_MacCabe Member Posts: 2
    Hi All,
    I too requested the ability to Align Views from different Parents and how good, the Support Team have delivered this and it works so well.
    You just need to redo the view you need aligned then select the target Parent view and right click the Child view then select the Alignment required and presto!
    Kudos again to Onshape Support :-)
