filled surface to create elliptical cap
lucymarie_manteselucymarie_mantese Member Posts: 24
edited July 2015 in Using Onshape
I am trying to create an elliptical cap the same as what is built using SolidWorks and described in this video link:
https://www.youtube.com/watch?v=GT-1c_jFI1g
I have been able to create the cap in OnShape using the approach in the video but I believe OnShape does not have a "Filled Surface" feature and I am therefore unable to "fill-in" the elliptical cap.  The image below is my current OnShape sketch.  I would greatly appreciate help completing a solid model of the elliptical cap. Thank you.
  • navnav Member Posts: 258 ✭✭✭✭
    Hi @lucymarie_mantese here an approach not 100% happy with my method below, you'll need to add more guidelines in parallel planes to fully define it, probably you'll get a better answer from some of the guys here that are better trained.
    Step 1: Similar ellipse as yours, with a couple of guide curves
    Step 2: Used the Loft Feature( surface)
     With just one guiding curve ( :s ) Not happy
    With 3.... not nice
    I suppose adding more guidelines will refine the profile. after having the surface fully define you can thicken the surface and obtain the solid.
    Here is the public model so you can check out what I did.
    https://cad.onshape.com/documents/68425bfa19834da49f6baeee/w/f59df980d1d64029a59c47fd/e/71244fc0a6ac48f98c538861
    Nicolas Ariza V.
  • lucymarie_manteselucymarie_mantese Member Posts: 24
    Nav, hi.  Thank you very much for the sketch, this looks really good.  I had tried using the Sweep feature but thank you for suggesting to use the Loft with guidelines.  Thanks again.
  • erwin_1erwin_1 Member Posts: 15 ✭✭
    Hi, if you want the loft follow specifically your sketch 2, you can use that as intermediate in your loft. Loft can handle more than 2 curves.
    See here: https://cad.onshape.com/documents/ddd3a078ea084f7bbcb77c81/w/5bb6a8f91a4c4a9998a34659/e/0501df609f5e47f88e4fe8e1.
    Check the tab V3.
    I made the loft from the first edge of sketch 1, sketch 2 and then the second edge of sketch 1.
    Guideline with sketch 4.
    HTH
    Hi @lucymarie_mantese wanted to share a video recreating the steps to accomplish something similar like the video from solidworks that you posted.
    The method used to convert the CAP to full solid was from @jakeramsley from this post
    https://forum.onshape.com/discussion/1180/surface-to-solid
    To create the section view at the end (Does not show up in the video above ) see here: https://www.onshape.com/cad-blog/a-look-within-onshapes-3d-section-view
    Nicolas Ariza V.
    In the general case, adding guide curves is not a helpful way to get a smoother loft; usually the opposite is true.
    One way to loft a smoother shape might be to create a number of loft profiles consisting of half-sections of the finished shape, but actually quarter-quadrants of an ellipse.
    Each profile would comprise a short vertical line upwards from the ellipse centre, at its upper endpoint it would join (at a 90 degree corner), to a quarter ellipse, which would travel away from the central axis curving downwards, ultimately arriving vertically downwards to pierce the elliptical boundary curve. A horizontal line back to the centre would complete the profile.
    These elliptical segments or quadrants (perhaps four in number) would radiate out from the central axis of the finished cap, sharing the same vertical leg, and the start section would also be the finish section. The only guide curve would be the elliptical boundary curve.
    edited August 2015
    Here's a simpler workflow to achieve much the same result as the method I described in my last post
    https://cad.onshape.com/documents/70f37346a0684b508492084f/w/891fd4042caa4cba9c676164/e/7cf781640cfd46f5bc40f0a9
    Basically, it follows the same idea of swinging a loft about a common edge, (more like a sweep --except it seems sweep doesn't work this way, in Onshape - it fails with "Self intersecting" error)
    but saving work by drawing only two loft profiles, at ninety degrees to each other, to make one quarter of an elliptical solid dome (same method could be used to create an elliptical surface, by omitting the two straight lines)
    This quadrant was then mirrored about the two vertical construction planes to make a whole dome.
    The resulting solid does conform to the elliptical curves at all the boundaries, so it is smooth in a gross way, unlike the result nav describes above as "not nice"
    However, Onshape does not yet allow making a loft tangency strictly normal to the start and end planes, and consequently when zebra stripes ("curvature visualisation") are added to the resulting body, it is clear that it is not optically smooth across the junctions. (You can see the same in nav's otherwise excellent v2 result, but he has only half as many junctions as me)
    I imagine that my first suggested method (producing a closed loft through four profiles all at ninety degrees) would give a smoother result, except that there would (I expect) still be a discontinuity at the seam between the first and last profiles. I'll check it when I get a spare moment.
    edited August 2015
    OK, I was wrong about the discontinuity: a closed (surface) loft through four profiles produced a perfectly smooth result, as the zebra stripes show.
    The common axis of all the loft profiles is shown in red.
    It was a bit tricky to set up: I had to "match vertices", specifying the outer ends of each loft profile, before the loft would accept sketch 1 (the closed, complete ellipse on the "Top" plane) as the guide curve
    The model is public, at:
    https://cad.onshape.com/documents/bf7b6aac098b412db7ba7d55/w/fcb46e5d13b64f5ab40412e7/e/73b058c2297a4052b4f801ea
    edited August 2015
    The key difference between the surface resulting from my latest post and irwin's similar v3 method is that there is only one degenerate point in mine (at the top of the red line) whereas there are two in irwin's (at each end of the long axis of the base ellipse, which he used as the axis corresponding to my red line). More importantly, the degenerate point in my method is at the location of lowest curvature in the entire part, whereas the v3 method puts them at the maximum curvature locations.
    Both models are smooth at the location of minimum curvature, on top, but this is not the case at the pointy ends.
    The resulting difference in smoothness at the ends is barely detectable, as the zebra stripes show, but perhaps might be noticeable in a highly finished part, or a metal injection mold tool. Probably what's more important is that degenerate points can cause downstream problems -- either within the modelling app (especially when you try to thicken a surface) or for (say) CAM processing of the result.
    I don't think the degeneracy here would be enough to cause such problems, but I raise it as an example which may interest some who will encounter more serious instances.
    Because of the lack of tangency controls in Onshape at present, it may also illuminate some additional loft options in a way which may help people get better results in the meantime.
    For those wishing to know more about degenerate singular points (which is essentially a mathematical breakdown in the description of the surface where all the splines converge to a point) there is some good material on the www.
    Here's one I just found:
    https://www.youtube.com/watch?v=uGZ7Ai0l3tA
    The problem when the splines converge is a bit like a contour map where the contours converge to a point: there is no way of computing what the local slope is at that location - and "does not compute" is a problem for computers (unlike humans, who can shrug it off)
  • kevin_quigleykevin_quigley Member Posts: 306 ✭✭✭
    edited August 2015
    Loft in no way compares to filled surface for the reasons demonstrated above with degenerate points. The bigger issue with degenerate points is they tend to create merry hell further downstream when it comes to shelling or thickening or other operations....which I see andrew said
    https://cad.onshape.com/documents/99f1fe911d07469c85979c37/w/fe2ba429b8b74a96b587695b/e/6d11baa1f4824e5fa5114bf4
    1. Sketch an ellipse and fully define it.  Make sure that the quadrant points are aligned some way (I made them horizontal on creation).
    2. On an orthogonal plane, start a sketch.  Sketch an arc that pierces the ellipse on the ends (use the pierce constraint, not the coincident constraint).  Use the split tool to split the arc and use a vertical or horizontal constraint on the point created to be in the same place as the center of the ellipse.  Fully dimension the center of the arc.
    3. On the other orthogonal plane, sketch an arc that pierces the ellipse at the ends.  Select the arc as well as the arc created in the previous sketch and pierce them.  Use the split tool to split the arc and make that point coincident with the point created on the previous arc.
    4. Start a loft.  For the profiles, select the elliptical face first and the split point second.  You'll get some cone-ish looking thing.  (I'm doing it as a surface loft, you can do it as solid if you wish.)
    5. Add the four arcs (two arcs that were split in two) as guides.  This should give you the shape you were looking for.
    6.  From here, you just need to do a two directional extrude of the elliptical sketch.  One direction goes up to the surface you just created.  The other goes as far as you want in the other direction.
    Jake Ramsley
    Thanks a lot @jakeramsley for a much simpler way of doing this.  ;)
    Nicolas Ariza V.
    @jakeramsley Thanks a lot for making your part available.
    @jakeramsley
    Nice demo, great method, thanks a lot.
    I did briefly wonder whether to have a crack at that: I recall successfully developing it for a Solidworks Model Mania challenge, many years ago, and subsequently feeling vindicated when the 'official answer' used the same dodge!
    I've redone the model using my less elegant method at
    using circular arcs like yours, rather than elliptical arcs - I should have taken the time to view the OP's clip, whereas I cheated by looking at the geometry others had posted -
    A question Jake, if you're still looking at this thread: I notice that the resulting solid (whether from your method or mine) has a lot of short edges around the sharp edge between the elliptical extruded walls and the domed top. Here are some of them, on your model:
    When I run a simple fillet (with tangent propagation) around this edge, I nevertheless get a single face on both models, which is pleasing -- and not entirely expected.
    However, if I try to achieve better curvature continuity with a conic fillet,  I do get a broken face, as expected. This happens in both cases, although rather more irregularly with your model - the duck egg blue one)
    I'm guessing the problem arises from a hit and miss situation where the elliptical extrude meets the edge of the surface resulting from the loft? Overlapping minutely at some locations and undershooting in others, due to the an algorithmic computation inevitably delivering a slightly variant result from an analytic one, possibly?
    I tested this by creating a slightly smaller ellipse for the extrude, and sure enough, I got a clean single edge, which even a conic fillet was able to sweep in one go. (refer the tab labelled "Smaller ellipse extruded" in my linked model)
    I used to encounter such problems all the time in Solidworks. I wonder if solid modellers of the future might alleviate such computational shortcomings, perhaps by temporarily extending the internal representation of capping surfaces slightly beyond the profiles extruded up to them? Saving us from confusing outcomes, which currently lead to us having to perform laborious and somewhat arcane workarounds...
    andrew_troup,
    I don't have a good reason why conical fillet are not able to remove redundant edges/surfaces while non-conical fillets can.  We have plans to upgrade our implementation of conic fillets in the future, which could potentially remedy the situation.
    As for the short edges that are shown, I believe that is the result of loft being an approximation and not being fully capped by the ellipse.  Doing the extrude from the ellipse up to the surface right on the boundary most likely hits differences at that edge based on the precision.  Rather than creating one single edge, it creates a bunch of them.
    Jake Ramsley
    Thanks, @jakeramsley
    for confirming that it's a boundary representation mismatch.
    Question: Can you see any merit in my suggestion that the internal representation of the cap surface be temporarily extrapolated/extended for the purpose of delivering clean edges?
    It seems to me something along these lines must already be happening, or the extrude would fail altogether? (I recall this happening routinely in the early days of Solidworks)
    It would be a plague, in a complex curvy model, if a number of edges end up being segmented in this way. There's more at stake than would be addressed simply by upgrading conic fillets, sweeps etc... paper over cracks is better than no paper, but not as good as no cracks.
    I'm not an expert in this area and don't know what potential consequences of this are.
    Jake Ramsley
    Thanks, Jake. I wonder if anyone else from Onshape would care to comment?
  • lanalana Onshape Employees Posts: 761 image
    @andrew_troup
    I think we should be able to get better edges here. Could you please submit a feedback on these documents.  We'll work on it. Thank you.
    @lana
    Yay! go the dream team! Will submit, con mucho gusto
    I would appreciate help with an export/import issue I'm having.  These were my steps to import a part from a public file:
    1) I opened the public file @erwin_1 made available in the thread above (thank you erwin_1)
    2) I made a private copy.
    3) I exported one of the parts (Tab 1) as Parasolid and downloaded it to my computer.
    4) I imported the part it into a separate OnShape file I am working on.
    5) The imported part shows up as a separate tab.  But it does not include the specific sketch information (Loft, etc), it only shows up as "Import".
    6) I then tried to include the imported part in an assembly but it does not show up in my assembly list.
    Is my import/export procedure incorrect?  Thank you.
    edited August 2015
    Hi @lucymarie_mantese you're not doing anything wrong just some clarifications about import/export:
    R/ Even if the document was originally done in OS after you export it as parasolid or other format and imported back to OS it loses all linked features (Sketches, features, etc performed in OS) , in other words it can be edited but using limited tools on OS like thicken for example if is a surface or move face if is a solid.
    R/ Check if the part you're trying to insert in assembly is a surface, at the moment OS assemblies do not recognize assemblies, this might be the reason is not showing up in your assembly list.
    Nicolas Ariza V.
    edited August 2015
    @nav Thank you very much for your comments about my import/export steps.  @andrew_troup Thank you for the link to the previous post.  I was able to "Copy to Clipboard" and import the part. However, when I try to make an assembly, the imported part is not showing up in the assembly list and I'm unable to make an assembly with the imported part.
    @nav suggested to see if the imported part is  listed as a surface and it is.  Is that the reason it can't be added to an assembly?
    I'd appreciate any suggestions.   Thank you again.
    @brucebartlett Hi.  Thank you for your suggestion.  After using the thicken function on the surface it gave me a part that allowed me to add it to my assembly.
  • jody_robinsonjody_robinson Member Posts: 9
    Hi all,
    I am quite new to CAD and OnShape (only a few weeks under my belt), and have been having decent luck with getting some ideas I have drawn out (lots of trial and error).
    I am currently working on an elliptical cap like the examples by @jakeramsley and @andrew_troup, and have used a copy of the sketch from Andrew's example to build mine from. I have changed the length/width dimensions so the long end is north/south as opposed to east/west in the example for consistency with all of my other parts, but height remains the same.
    The constraints seem to have adjusted as well, except for a "Sketch could not be solved" error in sketch 2 (see screenshots). However, I am able to run subsequent operations fine.
    I have not had any luck figuring out what it is complaining about. While in a perfect world I would love to fix it, is it really necessary given the extrudes and shell have worked fine?
    Thanks for any insight you can provide,
    Jody
  • shanshanshanshan Member Posts: 147 ✭✭✭
    jody_robinson, share your document as Public please , we can help you check why it happened
    Thanks to @andrew_troup for the pm with an explanation of why the issue occurred, and steps for fixing it.
