Okay thanks. However I'm assuming this answer means that it is not possible to set the low performance mode to on by default?
We do not have a low performance mode per se. However, you can manually set the tessellation quality to "Coarse" to use the least amount of graphical data, more information on how to do is in the documentation, here : https://cad.onshape.com/help/Content/appearance_editor.htm#tessellation
You will need to reset it to 'Auto' if you want the default behavior.
We do disable some of the graphics effects when we detect lower frame rates. However we do not have a way to manually disable this, as of now.
Paul
Okay thanks a lot for your guys's responses. Would you consider adding this to a future release? I think a lot of people would be more than willing to sacrifice appearance for performance. Again, thanks for the help guys!
