"show curvature" in skeches does not stick - no "final" button
roman_jurt190roman_jurt190 Member Posts: 46 EDU
hi all!
after closing the "show curvature" dialog, the selected splines loose the curvature visualization... like it is shown here.
but in the "curvature visualiziation improvemens" video, pressing the "final" button will continue to show the curvature... this is, for me, in most cases better.
- I don't have a "final" button...
- I'm an Educator and run an EDU-Licence... it this a Pro/Enterprice Feature?
- Did I miss a Setting? this button only seems to be mentioned here
thanks for some clear-up!
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,951 image
    The Final button only appears when you have features after the one you are editing - it regenerates all downstream features so you can tweak your model and see what effect it would have on the finished model.
  • roman_jurt190roman_jurt190 Member Posts: 46 EDU
    oh - how could i missed this:) but i see... the "show curvature" ist just only shown when the dialog is open... its just another box floating around... well - that works as well... the only downside is... when you go back and forth a lot between div. sketches to finetune... you always have to select the splines again...
