How do you manage your library components?
Phil_DyzePhil_Dyze Member Posts: 12 PRO
I'd like to know how you guys work for your business standard components.
For now, I'm working as Onshape Document as category, where all the components are imported in different part studios.
For example:
Onshape Document: Connectors
Bearings:
The advantage is that it's very easy to maintain and ensure each connector has the same design baseline (configuration, mate connector, etc)
It's also easy to find the connector document and navigate through it.
The disadvantage is that each time I add or modify a document, a new version is created. Using many different connectors from this document result is many "out of date" notifications...
How do you guys class your standard library?
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373 image
    It's recommended to do this as one part per document. We are traditionally conditioned to think in terms of a folder/file structure. That is not the case with Onshape. You should trust and lean more on the searching capabilities.
    Here is our documentation on library creation: https://learn.onshape.com/learn/article/best-practices-for-managing-custom-libraries
    Here is another forum conversation that talks through this a little bit from a searching standpoint: https://forum.onshape.com/discussion/comment/60682
    I'm more than happy to go more in-depth with you on any questions you may have.
    Twitter: @bradleysauln
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,050 PRO
    I used to do it the same way you do here. After a while the out of date notifications started to really get annoying.
    I later separated out everything into it's own document and Created a library folder to keep everything in one place.
    If you follow @billy2
    You will see he created a custom property called lib
    Then your whole company will be able to search for lib parts by simply looking at that property.
  • Phil_DyzePhil_Dyze Member Posts: 12 PRO
    Thanks! I'll definitely take a deeper look at this!
  • romeograhamromeograham Member, csevp Posts: 748 PRO
    edited April 2020
    @Phil_Dyze
    Just a quick note on version management if you have many library parts in one Document. If you use Versions, you'll run into the issue of every part in the document becoming out-of-date everywhere it's used (the problem you and @john_mcclary mentioned.
    However, if you release each part individually (using Onshape's Release Management), you can keep all your parts in one document - and they won't end up being out-of-date anywhere, unless you release a new Revision of the part.  The downside, is your Version & History tree will have a Revision for every part.
    I think the "one part per document" guidance is best here, but thought I'd mention this too!
    Oh that's kida nice. I still haven't messed with revision management yet.
    It works really really well. There are some peculiarities, but it does a great job of keeping track of Part Numbers, and Revisions (as it should!). This is a case where it can clean up those out-of-date notifications. - Which, like any Notifications anywhere (ahem, my phone) need to be kept to a manageable level, or they become noise and get ignored.
    I want the little blue notifications (for part or FS updates) to be important enough that I act on them when I see them.
